Well yes, the M113 bolts on to the R129 chassis...but it's entirely different mating an M113 kompressor to an M119 cylinder head.Well, m113 bolts on to R129 chassis with no modifications.
Doesn't matter. The ignition system is not compatible, so that would be have the swapped in its entirety as well for it to work huge job.but its single overhead cams. m119 double.
Hello FATHERTIME,If you find that thread on what he did to make that happen, it will take the dew off that rose.![]()
It is really not that complicated. This engine was made to be boosted, it was used in the Sauber c9 and c11 race cars and boosted to well over 1000hp on a mostly stock engine. Mostly just to lower that high compression ratio. The guys at Kangaroo team brought one of their m119s to over 800hp on stock internals and have beaten the hell out of it on tracks day after day, redlining while drifting. Only head bolts had to be changed to thicker stronger ones.When a manufacturer such as Daimler supercharges or turbocharges an engine, they have a lot of extensive engineering throughout the internals just to accommodate the extra boost and heat. I remember just to add a turbocharger to the old OM 617 diesel , a lot of internals such as the pistons were re-engineered. They also implemented an oil injection system to hit the bottom of the pistons to keep the heat down. I think to do the job right it is a little more than trying to find a supercharger that will "fit".
But what about the transmission? It doesn't break? 722.6 on SL500It is really not that complicated. This engine was made to be boosted, it was used in the Sauber c9 and c11 race cars and boosted to well over 1000hp on a mostly stock engine. Mostly just to lower that high compression ratio. The guys at Kangaroo team brought one of their m119s to over 800hp on stock internals and have beaten the hell out of it on tracks day after day, redlining while drifting. Only head bolts had to be changed to thicker stronger ones.
Hello AG129Check out Stern Garage in Germany $$$$
M119 Eaton TVS R2650 Kompressor Umbausatz
Hiermit bieten wir Ihnen die Möglichkeit Ihrem M119 Motor durch unseren Kompressor Umbausatz eine ordentliche Mehrleistung zu verpassen. Hier die einzelnen Komponenten: Eaton TVS R2650 lader mit speziellem Hals CNC gefrästes Aluminium-Saugrohr mit vier Laminova Kühlkernen CNC gefräste Halter für...stern-garage-shop.com
Their channel is always in German. The website can be translated though. They do a 6 liter conversion in addition to the supercharger. I think they also offer a 6 speed manual transmission conversion, I know the Slshop does offer a 6 speed manual conversion.Hello AG129
... now if only the video was done in English
And only 25k euros??? What a steal I'm about to get itHello AG129
