1999 and 2005 E55 AMG
Part number 113-202-04-19. Supercharger Drive Belt Idler Pulley. Replacement cost is in the area of $540. I just rebuilt mine for $27.
I pulled the belts off my car, spun the pulleys, and found three with dry bearings; serpentine pulley on the double supercharger drive belt idler pulley, serpentine idler pulley, and the serpentine tensioner pulley. I decided to replace them all but the cost of the above pulley was outrageous. I spent a few days researching and here is my solution.
See attached document for the part numbers and DIY info.
Hope this helps others.
Mod, if it is worth a sticky somewhere, I'd be glad to accept it!
:grin
Cross-posted at the other forum.
Discussion Starter · #2 ·
Update: per input from rockthemullet on the other forum, the Dayco 89130 is a direct replacement and requires no sanding.
17mm I.D., 89mm O.D, 6-rib, 26.4mm wide. This I would use as my first choice and the 89012 as my second choice if this one could not be obtained.
