E430, W210, stock
Hello everyone, i own 1997 slk230 kompressor for a month now, everything was ok till
yesterday when my supercharger stop working. I noticed that a problem is in a clutch,
three "screws" which were in some plastic plate on the beginning of clutch fall off!!
What to do? Is it posiblle to buy only a clutch? (tried search button but no luck)
Regards, thnx
1998 Mercedes 230 SLK
I suggest you have the electric contacts checked before swapping the clutch which can be changed separately (A1110970128) - often it's just a loose or corroded contact at the clutch or of the electronic relais. The plug for the clutch is beneath the engine cover, front end, left/below the camshaft adjuster.
E430, W210, stock
Thanks a lot!
