1 - 16 of 16 Posts
87 190E 2.3L
Hey all,
Are all sliding roof suppose to tilt also? I see lots of pictures of 201's with the moonroof tilted up...are they suppose to all do that or is that an option. As far as I can tell my 87 only slides back. Just curious..
CC
2008 Outback 2.5 XT, 2012 CNG Civic
yes, the roof should be able to tilt as well...
where is the switch located ? Otherwise, the manual simply should tell you what to do.
In my 93 MB190 you simply push the switch upwards.
'85 2.3-16 '99 C280 '11 GLK350
It all depends if your '87 was built in the first part of the year or later, since it was a mid-year modification. You can check the build date on the data card on the driver's door jamb.
190E, 993
CCWHEEL - 4/8/2005 3:51 PM
Mine was built 11/86, so I am guessing mine does not have the option??
CC
Nope. If you had the tilt/sliding sunroof, the switch would be adjacent to the front dome light (in the roof). The regular sliding sunroof switch is dead center on the dash, next to the antenna and rear window switches.
'86 190E 2.3L
i know the manual sunroof opener is on the left side of the trunk, im just not sure what part comes out to turn it....check out the pic in the owners manual.
Syracuse315 - 4/10/2005 8:42 PM
'86 190E 2.3L
first look at ur owners manual...the page about opening and closing the sunroof in an emergency
I know about the manual operation of the sunroof, and the driver is part of the OEM toolkit . . . I was just wondering what it had to do with this thread.
'86 190E 2.3L
MTI, the thread just reminded me of that problem...by the way could you describe exactly where the thing is i need to twist to open the sunroof. Thanks
The "socket" is part of the tool kit, but a metric (17mm?) will work.
'86 190E 2.3L
tried it and it doesnt seem to work...I pressed the sunroof button and I can hear the motor push it back and forth but I think the sunroof derailed or something..any suggestions on getting it back on the track or should I take it in?
The sliding mechanism is pretty simple, so I doubt that the panel has "derailed." It's more likely the braided drive cable has come off or broken. Fixing that will call for removing the headliner . . . not my favorite job.
'86 190E 2.3L
ahh...i'm thinking this would be a good time to lower my head, hide my face, and take it to a "trained" professional.[xx(]
1 - 16 of 16 Posts
