Anywhere I could find info on servicing a sunroof that was working up to a few days ago. Now catches on right side sliding back to open, tilt doesn't work now either.
Thanks Jody
07 E63 + 07 CLK63 Cab
Hello
Since you did not state year or model, I am assuming more than 5 years old. Try to get it open then apply some lubricant onto the aluminum slide rails. Silicon spray or maybe even vasalene lightly applied with a small brush. Light oil on hinges if it has a sort of wind delflector. Maybe I am completely off base but usually its a lube issue that starts the problem. More info would be helpful. :)
