98 sl500
I just purchased a 1998 SL500 for my wife. The plastic flap that covers the mirror on the sun visor has cracked and is a dark yellow color as compared to the rest of the visor. Should I replace the whole visor or is the mirror insert assembly available as a seperate part. Also, the housing that contains the two map lights and the rear view mirror has cracked on one side. The dealer told me 700+ as the whole assembly must be replaced. Sounds like he might be full of it. The mirror and remote functions and lights all work fine. Any advise on what I should do?
BTW, both sunvisors have changed color. Is this a common problem? Is there a good place on line to get parts?
Thanks in advance.
visor mirror
You can replace just the mirror insert as a whole. I did it on mine and and the color was different due to age that i replaced the other one About $55.00 each from dealer. I don't know about the upper mirror piece i replaced my with wood for $250
98 sl500
Where did you get the wood?
I assume you are talking about the housing that contains the map lights and rearview mirror? Where did you get it? Real wood or fake?
Thanks.
yes, replaced the housing with real wood, from (performanceproducts.com ) you can reque...
yes, replaced the housing with real wood, from (performanceproducts.com ) you can request a catalog from them
