sun roof wont OPEN !
1353 Views 4 Replies 1 Participant Last post by  Guest (MBNZ)
the saga continues..<br>
A few weeks ago i posted that 'my wouldnt close'<br>
Ifound that the switch was the problem.(AUD$85)<br>
<br>
Now it wont open<br>
<br>
This time i dont think its the switch, when i push it to open it TRIES to move, and maybe dose a 1/4 of an inch, but thats it.<br>
<br>
My patience is running low with this car.<br>
<br>
any help thanks louis<br>
In the boot (trunk) on the inside left you should find a hex socket in a bracket and manual winding shank for the sunroof in case the electrics fail. Its detailed in the W123 handbook which comes with the car. Hope this helps (mines a 77 230 coupe)
Re: Re: sun roof wont OPEN !
thanks but the manual winder seems to lack the style the swich in the intior of the cabin<br> <br> i dont think its the motor because when the roof is closed (which now is perminant) and u accedently push the button to close it futher u can hear in the back the motor turning away ,doesnt sound healthy (like a heavy duty masionry drill).<br> if i try to open it there is no visable movement of the foof but i do think it dose move a bit.<br> <br> thanks for any help<br> louis<br>
Re: Re: Re: sun roof wont OPEN !
Either the clip that holds the cable on the track has broken, or the cable itself has broken. Pretty easy fix. I've had this happen to me several times. $75. Good luck.
Re: Re: Re: Re: sun roof wont OPEN !
thanks <br> i have booked the car in to be fixed (2 week waiting list) few dollars for the part $50-$60 labor.<br> <br> will post again when i have more info or when it is working again<br> louis
