: as of last week the electric motor in the roof decided thst it would only open the sun roof and refuse to close.<br>it opens easy (without struggle)<br>but when its time to close, i get nothing not even the sound of the motor, just nothing.<br>please help in finding the problem.<br>i am hoping that someone will say its just a matter of a new switch in the dash.<br>thanks louis<p>My problem was the opposite. Would not open, but closed great. I found it was the switch. If you take off the plastic piece that covers the motor, you can find the wires going to the motor. If you take apart the connection, you will find 2 wires. If you put a ground wire to one, and a positive wire to the other, the sunroof should go one way. Then reverse the wires, and the sun roof should go the other way. If this works, then your switch is probably bad.
