1 - 9 of 9 Posts
'86 190E 2.3L
I installed a new deck in my 86 190E and I was wondering if the white and red sockets( In the back of deck) that I didnt use, were for subwoofers?
ML430
That red and white jack on your deck is for a signal for a amp for subs or something of that sort.
ML430
Red - Stereo
White - Mono
Just a guess
ML430
Ok man, here is basically how you install a amp/sub..
+ = Red
- = White
HU
RCA's
AMP
'86 190E 2.3L
Discussion Starter · #7 ·
So your running both the red and white lines to the sub(s), then a diffrent line from the subs to the amp, right?
ML430
Ok, let me explain how to install a whole system to you...
You need + constant from the bat to the amp. THen you need a + remote from the HU to the amp. The AMP takes in the RCA input(the red and white) to feed it a signal. Then from the amp there is speaker wire that connects to the sub to give the sub signal.
That is a quick howto. Hope this helps.
1 - 9 of 9 Posts
