15 ML 250 BlueTec; 02 Sequoia
My car did not come with plates, and I'm going to pick them up this week.
Any idea what bolt size holds them on?
Thanks,
Boris
Not stupid at all, and this has been asked before. The Mercedes license plate bolts have a pretty narrow thread pattern and I would just buy them from a dealer. I don't know if Joe's Hardware would have any that are comparable.
1994 E320 Wagon,1999 E320 Wagon,2000 E 320 Wagon, MGB Track/Rally, ,1988 300E ,more....
Ask
MARK CUMMINS he has the specs ,lowes carries metric ss bolts
:bowdown:
Ask
Dealer will probably comp install plates if you act like you are interested in the future use of their services:eek:
:bowdown:
'07 GL320CDI
Rear bolts are M5 (metric). About M5X16 should do it.
In metric speak this means a 5 mm shaft diameter bolt, 16 mm long measured from under the bolt head. There are indeed different metric thread pitches, but there is also a "most common" pitch for each size, and that's what you'll find and that's what you need. TruValue will have these, even in stainless, even in allen head. The black finish screws will rust.
This all is applicable if threaded inserts have not been previously damaged by someone using incorrect--read SAE--screws.
Front plate mount system can be anything as it's a dealer install system. No experience with this as in my state no front plate requirement.
