I am replacing the old style filter with the new one and I see that I need three new fuel lines. Are all of them different or can I just buy whatever line is different. And if so any idea on which one I need to get? This is for a 2000 ML 320
It was fun while it lasted
You will need to install the fuel filter and fuel line upgrade kit, 1 Part # 163 470 28 64, 1 Part #163 470 29 64 and 1 Part #163 470 37 64. The last info I have on the KIT Part # is 163 477 07 01 and I think it includes the filter with the lines.
As cmitch mentioned, you'll need three new and different lines, all with distinct part numbers.
Check out the pdf for the illustration of the corresponding lines. The pdf references the older filter (05-01) but you will need the latest (07-01). The lines do not come with the filter.
