1993 400sel, 2002 corvette ZO6, 1980 L-82 corvette, jeep cherokee, durango
Hi all,
I'm in the process of changing my water pump in my 93 400 sel and in order for me to remove the last bolt it looks like I need to remove the harmonic balancer. Is there any way around removing it? If not is there an easy way to remove the main bolt on the pulley? I really don't want to buy a crankshaft locking tool that i'll never use again.
I'll take any advice you can give, I hope I didn't bite off more than I can chew on this project.
Thanks Eric
84 500 SEL ...94 S420..... 95 S500.... 96 S500 95 S600
Dont buy the tool!
You wont need a locking tool,just use air gun...blast that baby off....Ive taking a few off this way..
1997 S600 (sold)
If you don't have an impact wrench or don't have the space to use it on the engine in the car, use the access hole on the bottom of the transmission below the ring gear to lock the ring gear with whatever you can find. I used a short piece of square rod wedged in place to remove the harmonic balancer and a longer rod placed through the ring gear to reinstall it.
V12 Uber Alles, Changing the Front Seal in a W140 Mercedes Benz
Brett
current fleet: 1996 s500; 1997 BMW 328ic; 2000 Nissan Frontier; 1966 AC Cobra
The harmonic balancer had to come off of my car(1996 s500) to get the subject bolt off for the water pump.
No work around available - it has to come off.
Good luck
Moderator
SL55, 300SE, GL450, Daytona 955i
Air tools are the bomb... :D:D:D
