12 odyssey (90k) 1995 E320 wagon (307k) 1983 500se (172k) 1995 Cabrio (123k)
Any tips to get this bugger off?
I have moved it out
Plant Terrestrial plant Gas Automotive tire Circle
Gas Plumbing valve Tool Recreation Cylinder
about 1/4 inch.
Used pry bars, cv forks, 5 lb slide hammer with cv " hook".
Also drilled through "stub" exposing diff stub spline, and penetrating oil through the hole.
Next up im going to drill 75% through the base of the remaining "stub" along a straight line then air chisel through the dimples it creates to try to split it along a straight line.
Anyone have any ideas i havent tried?
Discussion Starter · #2 ·
Overnight pb blaster soak fresh set of patience...gtg
Outerwear Sleeve Textile Collar T-shirt
