Hello everyone,
I was hoping that there may be someone here that can help shed some light on a stubborn overheating issue I have been trying to troubleshoot. I recently changed the water pump and thermostat, and flushed the coolant as part of maintenance. The old coolant was starting to get discolored and I already had everything apart to take care of the timing chain rattle which gave me a check engine light.
After all of that work, I found that there is one situation where the car will start to overheat - which is when I have the car at a long stop light, or a long idle ONLY WITH THE AC ON. Without the AC on, or with the heater on, no issues - I can go up hills and all over town without running into an overheating problem. The second I turn on the AC, all hope is lost. I verified the temperature through my Autel scantool and I can see the coolant quickly go from 215F to 240+F within a few minutes.
The entire cooling system has effectively been replaced, brand new radiator, brand new water pump, thermostat and all. I can see the radiator fan working and it speeds up and slows down according to vehicle speed and coolant temperature. I can't for the life of me figure out why it only overheats when the AC is on. I have checked the AC system to see if it was over or under charged and the pressure was within specification and the AC does blow cold.
Please help with any ideas, I've run out of just about every idea.
Thanks everyone in advance!
