1 - 9 of 9 Posts
93 300E 2.8, 79 450 SLC
Boy, I spent an hour and still can't get the oil filter canister cap off. I've used a cap removal wrench ($5 from Kragen; made with plastic) and even a channel plier. The plastic removal wrench from Kragen is totally useless. It slips out every time. I think I need a metal removal tool. I search online. Looks like the metal removal tool is around $19-$30. Any recommend brand and where to buy?
I hate the original oil filter canister cap design. Why didn't they make the cap like the ATF housing cap? Easy on easy off.
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
because
It wouldnt be original engineering would it. Did you remove the center nut of the cap first? If so then the housing lifts straight off. No threads no anything. All there is is that center nut with gasket and an O-ring at the bottom keeping it sealed. My first time was rough so I spun mine by hand to break the n seal then wiggled it pulling on it straight to get it out. If you do It every 3000 miles it wont be hard next time.
Good Luck
woah woah wee woah.... 400e's have different caps... :).... i just bought the tool, but what i used was a piece of small hand towl and a oil filter traditional metal looking like plier opening thing... works out in my 4-5th try... might i say, fabulous car... i have the same color as you! how many miles? to see whos is better ;)
The cap on the 300E is not center nut type. I wish it is. That will be easy. It's a screw on cap.
My 300e has 72k miles. :)
R129 SL 500 97, W124 E320 Coupé 96, W124 300E twin turbo 90, W126 300 SE 91, Ford Capri 2.8i 84
MB have a surprisingly cheap special tool for this, which cost me less than USD20.00. It works on the canister cap on my Coupé and the spin-on filters on the M103 engines. Part # MW103 589 02 09/00.
Discussion Starter · #9 ·
Just want to update this thread. I returned the plastic oil filter wrench (didn't work) to Kragen and bought a metal one from Autozone. The metal one is very similar to the RiteFit. Also bought a 3 feet metal pipe from Home Depot to get more leverage. Finally get the dame cap off.
1 - 9 of 9 Posts
