Get a set of Mercedes specialist spring compressors for the job. They can be rented.ARE THE SPRINGS EASY TO REPLACE? BECAUSE SOME PRIOR OWNER OF MY E320 LOWER IT BY HEATING THE SPRINGS, EVENTUALLY GOING TO REPLACE W/ EIBACH
The straight answer is no. You need to replace the entire front strut assembly. The shock absorbers' cylinder is the struts body itself. Unlike other car (i.e. BMW E30) the shock absorber cylinder (capsule) is inserted into the strut's body which allows replacement of only the shock absorber while retaining the struts.Is it not possible to replace only the shocks without replacing the entire strut assembly on this car?
