Hi all, I have a C180 K, recently had a service, new plugs, PCV hose and cam magnates and cables upgraded, Auto serviced. Car runs really well apart from first start up when left overnight. The engine shakes and splutters before it fires up, once or twice cut out and restarted. The revs jump up high to combat the start then all is OK. All other start ups in the day are perfect. Just when its left overnight.
I live in QLD Australia so temps are warm all year around.
2004 C230 sport auto. Eurocharged tune with HR lowering springs plus some other custom mods.
Check your fuel pressure. Mine struggled at start up and would sometimes not start on the first try. It turned out to be a cracked line inside the gas tank between the pump and the sending unit keeping the pressure from building properly.
That's a picture of the line. When I pulled it out of the gas tank it literally just broke apart in my hand. The crack was letting the fuel pressure bleed off overnight. If I were to start the car then turn it off and then immediately start it back up it would start fine.
This is very helpful thank you! I will get that checked out as the car is under a warranty
Update, took the car back to the dealer as a service was due to keep the warranty. Only did 3000km since the last service 6 months ago! Anyway.. friend of mine who's loves his Benz suggested a fuel filter change. Dealer said it was very sludged up and 8 years old. Seems much better now. did stall once in the last week starting but otherwise much better!
05 C55 AMG
That’s right!
NEVER forget about the fuel filter!
I’m glad you were able to resolve your issue.
