In my short experience so far in off-roading a W163, one glaring weak area has come forth: The suspension. The truck otherwise is great. Great fully boxed frame, great 4x4 system, but a woefully weak and piddly suspension system, designed for the minimum effort required to pick up some flashlight batteries and duct tape from Walmart during a mild flurry and then swing by the daycare to pick up little Jimmy.
Here are my gripes:
Here are some possible fixes that I can think of:
Anyone else have ideas and/or experience? I know that people who have off-roaded the ML have run into these issues...
Here are my gripes:
- The upper A-arms are absolutely dinky, and do not line up with the lower control arms at all, as far as pivot points, etc, which means the wheel camber varies wildly with suspension position.
- The upper A-arms have "fixed" ball joints which are non-replaceable (without replacing the entire arm), and appear to be tiny and undersized, with no options for upgrade.
- The upper A-arms are attached with bolts in slotted holes, and they tend to slide around with relatively minor tire impacts while off-roading.
- The front shocks have a whopping 2" of travel. Of course, this has already been explored by others before me, and the fix it using rear shocks from a 1997 4runner. A suggestion by another stalwart individual is also to install limit straps on the front suspension to prevent hyper extending the driver's side CV axle with the additional travel given my by the 4runner shocks.
- First and foremost, address the slotted bolt hole problem. One fix is to install this kit. You would need qty two of those kits to do front and rear upper control arms. I have confirmed the eccentric bolts included in that kit are M12x90, which is the correct size, and long enough to accommodate the capture plates. A slightly cheaper way to address this problem is simply weld washers into place over the slotted holes to effectively "remove" the slot, so the bolts can't move. This is the approach I am taking, as I plan to do a solid axle swap next summer anyway.
- Weak ball joint problem: Another option for handy folks is to fabricate custom upper control arms using universal parts from barnes4wd for example. I would make a custom control arm with two of these, some DOM tubing, and a joint like this to replace the ball joint. It would take some precise measuring and welding to do correctly, but you can make it any size you want, and you can make it adjustable as well so that camber can be adjusted by lengthening or shortening the A-arm.
- The ultimate fix: Solid axle conversion. From my internet searching, I may be the very first person to do this (once I get started this coming summer), but this would accomplish many things. It would eliminate all factory suspension weak points, would open opportunities for custom gearing and lockers, and essentially unlock unlimited suspension lift and tire size options. A couple potential difficulties: First, retaining the 4ETS system. Somehow the factory wheel sensors would somehow have to be retrofitted to the solid axles. Second, steering. The W163 has a factory rack and pinion steering system which can't be easily adapted to a solid front axle (usually solid axle trucks use the "steering box" w the pitman arm). One option is convert to full hydraulic steering, or adapt a "steering box" system to eliminate the rack and pinion. I do not have any idea which one would be easier.
