2003 CLK 500
Has anyone noticed a large popping sound when making slow sharp turns in a CLK 500? I don't know much about parts, but it's almost as if it sounds like something is popping into/out of place in the front axel. Obviously, I have no clue what it is, but thought someone on here could help!
2006 CLS55 AMG, 2000 E55 AMG, 2009 GL550, 1954 LINCOLN CAPRI. 1967 VW BEETLE
I had a similar noise a while back , it was my wheel bearing. Yours could be a wheel bearing too, or a balljoint, steering shock.....there arent axles in the front of these cars
A good independent shop w/benz experience should be able to pinpoint that noise for you
2004 CLK 240 Coupe
Whats your mileage? And have you checked the dipstick in the Steering oil reservoir.
If you do a 'search' here, you will find this topic has come up before.
CLK 350
This may sound odd, but take a look if anything has gotten itself wrapped around your stering linkage. Remove the panel beneath the dash and above your pedals and take a look. I had that problem and some cables had snagged themselves around the steering mechanism.
