Moderator
190E, SLK350
The car was driving fine, then suddenly the check engine light came on and the car lost some power and I could feel it like it was missing or shaking the engine.
It drove like crap until I got home. I turned off the car then started it back up to drive into the garage, the check engine light went off and the car behaved normally.
Puzzled, I grabbed my code tester and hooked it to OBD port. No errors were stored or found!
I checked in the intake manifold regulator for broken actuators but they were fine. I removed the air filter assembly to see if there were any obstructions... Nothing!
Revved the car, drove it around the block, no issues!
Strange....
Moderator
190E, SLK350
Discussion Starter #2
Found it!
The vacuum activated flapper (the big one in the center) was cracked!
2609956
Moderator
190E, SLK350
So far so good! Today's test drive was positive, no check engine light and no stored code. YES!!!!
Moderator
190E, SLK350
Car passed state emissions test!
I highly suggested that everyone checks the intake manifold's swirl control for cracked cases or broken links.
