I have a 2000 c230k sedan and I am wondering what the stock spring pad is? I've been told that is 3 dot pads stock. Is this correct? I am wanting to put 2dot in front and 3 dot in back or 1 dot in front and 2 dot in back. What do you think about that Luke? Thanks[?]
CLK55/G500/E55/ML55/etc.
The pad varies depending on what options your car had installed at the factory. The easiest way to find the size of your pads is to look at them. The second easiest way is to plug your VIN into the EPC and see what it was built with.
-s-
Dealer. They are called "spring shims".
-s-
-s-
