1999 CLK 320
my rear speakers stopped working only the front ones work. i was wondering what this could be. is it the amp or is the amp connected to all speakers could it be a fuse? it sounds terrible without the rear speakers. im looking for all opinions but if your guessing please let me know and if youve had this problem and you know what it is please state that as well
2001 CLK 200 Kompressor w208
must be the wiring or your speakers must be totally busted. i had mine changed cuz of gargling noises which i later found out that the original speakers are already torn apart :) try DIY in removing and checking the speakers so you could test it
2004 (w220) S500 & (R230) SL550 2007 & (W221) S550
check settings
Its possible the FADER control is set all up front.
Just double check it. Press the button under the radio lcd screen that is on far right and work thru menus
