2000 SL500 Designo Edition, 1992 500SL, 1991 300SL, 1977 450SL, 1999 E320 4matic Wagon
I'm having a problem with the Antenna hookup. My 2000 SL500 did not come with a radio when I recently purchased the car. I had a stock radio out of a 1999 SL so I'm using that radio to install in the 2000SL. All the stock radio hardness was intact and everything work just fine except the antenna connection in which does not fit in the stock Mercedes radio. Am I missing another fitting that would connect to the antenna end or is the antenna wire completely not the correct antenna wire?. I've attached some pics that could explain further my problem.
