Alright,
Well. my 300te has seen better days. About a month ago after installing a new radio the car was turning over but wouldn't fire. I pulled the spark plug wire and found that it was sparking but wasn't getting gas. I then went to the fuel pumps and found out they weren't getting power. I then did the troubleshooting and found out the fuel pump relay was bad. I jumped pins 7 and 8 in the relay and the fuel pumps ran and then I got the car to start. HOORAY. But then I was looking under the hood while the car was idling and I pushed on the air flow sensor. As soon as I touched the sensor the car shut off, and then I couldn't get it to start again.
I figured I'd wait until the new relay came in to proceed hoping that the problem wasn't anything major. I put the new relay in and I can hear the pumps running so that problem is solved. But the car STILL won't start. I pulled the spark and it was very wet with gas.
