stox - 2/15/2005 7:57 PM
If you are seriously considering it, do the following:
1) Hire an outfit like Carchex to take it for a test drive and inspection.
2) Find out if the service records are available.
3) Run it through Carfax.
4) Be suspicious of a dealer who doesn't know enough about the car to know that it has an I6, not a V6.
Personally, I avoided the '97, it was the first year of the electronically controlled five speed. On the other hand, I have not seen reports of head gasket and wiring harness issues that the '95 and '96 appear to have had.
You still might want to take a shot at the $15K car you found. Make'em an offer, assuming it is in great shape, and see what happens.
Actually that's where you're wrong.
The problem with the 5 Speed electronic tranny seems to be with the aggresive programming.
To my knowledge it affect most car with 5 speed electronic tranny from (1997 C36-1999 C43, CLK430, E430 as well).
The 1997 is the quickest and the has all the newer gadget such as Climate control unit, newer steering wheels, Seperated AMG script on the trunk (1995 and 1996 is one unit with black base)
here is the spec for C36 in US
1995 C36
3.6L I-6 DOHC
268 Hp/280lb-ft
4 speed auto
2.82 rear diff
older style steering wheel
older style climate control
number of car imported and sold in US:
444 (although I could sworn that the number used to be 538 or close to that last time I checked on MBUSA website ???
1996 C36
3.6L I-6 DOHC
268 Hp/280lb-ft
4 speed auto
2.82 rear diff
newer style climate control
338
1997 C36
3.6L I-6 DOHC
276 Hp/284lb-ft
5 speed auto
3.07 rear diff
newer style steering wheel (same styling as W208 CLK55)
236
1998 C43
4.3L V-8 SOHC
302 Hp/302lb-ft
5 speed auto
3.07 rear diff
Xenon/HID offered as option
579
1999 C43
4.3L V-8 SOHC
302 Hp/302lb-ft
5 speed auto
3.07 rear diff
546
2000 C43
4.3L V-8 SOHC
302 Hp/302lb-ft
5 speed auto (tiptronic : P R N D - +)
3.07 rear diff
Avantgarde grill came standard
Xenon/HID as standard equipment
very rare and some says they were only 50 unit sold
PS: If you really looking for C36, I would go with 97.
Also it would help if you could buy it from an enthusiast that really maintain and have all service record history of the car.
Hope this helps.
Regardz,
J Irwan
