'07 C280 4matic, '06 530i, '98 ML320
I would say that you'd have to remove the plastic cover and lube the wipe linkage. At the same time, you will have an opportunity to look at the linkage for any worn/cracked parts.
C200....E320
best to replace with a good 2nd hand unit (your old unit is on its way OUT), cost about $60-80
very easy to replace 1 hour or maybe 2 depends on your DIY skills
