Purchased a replacement liner/sound absorber/heat shield for under the hood of my 82 240D sedan some months ago....brand new and spanking clean. Went to auto parts store and bought "extra sticky" spray adhesive with which to install this padding under the hood. Worked great for about a month and then it started to come down. Bought another "industrial strength" spray adhesive and re-installed hood padding.....worked great for several months and then it too came down on the engine.
My sedan does NOT have holes in underneath the hood with which to use plastic grommets (sadly)...in fact, there are NO holes for this purpose. The OEM padding was shot to hell from 30+ years of use but those small parts remaining still stuck to the hood bottom.
Does anyone have a clue about what adhesive will work to allow this new padding to remain fixed under the hood? I live in Florida and the combination of moisture/humidity and rainfall makes for a challenge on this front.
Thanks in advance for any advice you can provide......:surrender:
