I have moved my spare wheel to the ground as it is in perfect shape and traded one wheel from the ground. The wheel has a sticker which says "Do not exceed 50 MPH" What is the purpose for this? The spare is full size.
I am in the process of removing the sticker.
W124 Moderator
Most likely the speed rating on the spare tire dictates what the sticker says.
Sent from my XT1710-02 using Tapatalk
I think I just figured it out. The wheel came from my S500 which had the AMG 18 in wheels. The spare is a 16 inch so I think the spare would be an odd ball and really create problems at speed.
I finally got the yellow 2 inch diameter sticker off the wheel. Hair dryer was used to heat it up and it peeled right off. Used some drip-strip to get the glue residue off. Bug n tar remover, WD-40 or Mineral spirits did not touch it. Hopefully the drip-strip did not hurt the finish. Internet suggested Goo B Gone, but I did not have any.
Ursula is just about ready for cars-n-coffee this coming Saturday at the Amelia Concours.
Mine has no such marking but giving you 16" spare when the car come factory on 18" wheels is stupid given what you are paying for the car. Your journey is instantly compromised if you get a flat given the 16" is basically an upgraded space saver wheel if you are on 18's.
I put it down to another Mercedes engineering failure, this time in the tyre well design.
I guess it saved on sale price. $300 (?) Standard wheel vs $900 AMG wheel.
As above im sure it was poor design from the engineering dept rather than cost as you can't fit a 18" wheel in the wheel well, they couldn't make it bigger in the current position as it would hit the subframe, but you still have have to lower the subframe to the floor to do diff mounts because there is no room to remove the bushings due of the wheel well.
Moderator
Wouldn't the overall wheel/tire diameter be equal on the 16"/18" combinations?
16" is a smaller rim but taller tire profile, 18" is a bigger rim but slimmer profile -- wouldn't they have to equate, otherwise the speedo would need adjustment too?
I would think an 18" spare would fit the trunk fine... no?
About this Discussion
4 Participants
Thom_7
Mercedes-Benz Forum
Full Forum Listing
