1 - 14 of 14 Posts
2001 430 Orion Blue
Has anyone upgraded the stereo system in a CLK 430?
I'm considering changing the speakers.
2001 430 Orion Blue
Hi. Did you change the head unit? I still want to control the volume and cd changer thro...
Hi. Did you change the head unit? I still want to control the volume and cd changer through the steering wheel. What speakers did you use for replacement?
Joe
2001 430 Orion Blue
What speakers replacements did you use?...
2001 430 Orion Blue
Did you replace all speakers including the subwoofer and how easy or hard was the installa...
Did you replace all speakers including the subwoofer and how easy or hard was the installation?
-06' CLS500 Lorinser-08'-MC Design Whips Project SL -06' Land Rover-
I changed all the speakers in the door and bypassed the factory amp. I was using the fa...
I changed all the speakers in the door and bypassed the factory amp. I was using the factory amp for a while but needed more power. The car uses a 61/2, 4, and 3/4 inch tweeter. The door panel comes off fairly easy. I did leave the factory subs in the back deck and used them for fill off the new amp.
Mark
2001 CLK 430
Re: I changed all the speakers in the door and bypassed the factory amp. I was using the fa
Mark
You said the door panel came off easy. On the driver side I tried, and I am scared to break anything. I took off the one screw behind the SRS piece. Are there any other screws?? I am able to pull off the bottom because it snap in. I think there is another screw somewhere? COuld you give me some hints how to take it off. The reason I am doing this is because the left speakers make a noise like when a cell phone signal interferes. My cell phone is not even rinigng. It happens once in a while, but is annoying. Any clue?
2001 CLK 430
Re: The door pull has a cover that comes off and has two screws behind it....
How u take this piece off? Did u use a flat hard and just pry it off?
99 Clk 430 Lorinsor springs 19" Oz Opera/ 00 ML 320 19" Moda R6
re: subs and aftermarket amp
how did you hook up the rear decks subs to an aftermarket amp? how did it sound?
2001 CLK 430
Door pull is not coming off
Mark I appreciate all you help, but I still can not get that door pull to come off. I used a flat head with a cloth over the head and tried to pry. I did not pull that hard, but it still not coming. I tried with my fingers and nothing coming either. Please help me, I do not want to break anything.
My door has the door pull attached to that piece I am trying to remove which is behind the door pull. To the left is the nice decorative plastic brown thing that is about 2 feet long. I tried to remove both of these, but not having any luck.
1 - 14 of 14 Posts
