1999 s500 2012 e350
need help in removing the steering wheel, what is the size of the bolt or nut holding the airbag,
R129 SL500
Torx T25
1998 SL500, Panoramic Roof, Factory Xenons, Black/Black/Black 2012 GLK350 Black/Beige
On my '98 it is a T-30 torx. You need to have an extended length Torx; mine are 6" long. They need to be at least 4" long, and 6" is about as long as you can go and still clear the dash. I bought a set of Gear Wrench brand from Amazon fairly cheap - 10 bits from T-8 to T-50.
'03 SL Kleemann, 1997 SL320 Pano Top, Tesla Model X
Threadlock on steering wheel
The steering wheel bolt itself is quite hard to remove on some of these. Of course, they use threadlock... I find it best to soften the threadlock with some nail polish remover (be careful not to get it anywhere else), and use an impact wrench for the steering wheel bolt removal.
Some tough cases also require careful use of a heat gun. The worst one, I've had to drill out.
Do not lock the steering wheel upon removal...
Just thought I'd add to this NOT to lock the steering wheel when you are trying to break loose the bolt, or you might jam the steering lock. Hold the steering wheel with your hand while applying torque to the bolt. See the following, excellent thread on what happens if you torture your steering lock, and how to fix it: http://www.benzworld.org/forums/r129-sl-class/1592845-ignition-switch-lock-1998-sl.html. Great work, patfarrell, aam, and WarrenC!
Here are the steering wheel removal instructions from the W210 forum: http://www.benzworld.org/forums/w210-e-class/1290713-photo-diy-steering-wheel-removal.html
-Klaus
[email protected]
