1 - 9 of 9 Posts
1990 W124 300CE-24
I have searched and searched but have found no definitive answer; would a 1999 W202 C-class sport steering wheel fit on my 90 CE (I'd disconnect the airbag of course).
Cheers!
W124 Moderator
The short answer is no. The horn contact is an entirely different setup. Clock spring vs carbon contacts and contact rings. Also not sure of the wheel diameter vs your stock one. Up to 94 W124's is a dead swap and you get to have the airbag.
Sent from my DROID2 using AutoGuide.Com Free App
Cruise Control
'87 300TD/'90 300D/'94 Quattro/'89 Vanagon TDI/'01 EV Weekender VR6
I have a 202 wheel on my '87. It takes the contact ring from a '92-'93 wheel
1990 W124 300CE-24
So it seems it will fit but mods. needed. Ok cheers for that!
Cruise Control
Yep, here's a pic of the contact ring (squibb) you need.
Cruise Control
It's a C36 wheel, so it's basically the same 390mm size as a Sportline/036 wheel, but it has a section of grey leather at the base of the rim.
1 - 9 of 9 Posts
