Ahaaaa, this time you were much clearer and you convinced me that there is a connection between the mirror wires and steering tilt. So, you actually removed both mirrors and made "only" a new insulation of the wires? That's the whole point? You did not replace any wire?
thanks and best regards.
Sorry if I was not clear and a bit speedy! Yes, I was having erratic tilt movement with the one fuse that goes to memory, power seat, etc kept blowing the 20A fuse. So I went to a 25 A fuse for 2 months. Then it blew and I went to a 30A fuse. After that blew a couple times. I noticed smoke from the mirrors when I fully retracted the mirrors then I was convinced the mirror wiring was faulty BUT could not determine until removed the housing and saw all kinds of wiring shorting/melting.
In the mean time whenever the tilt didn't move based on the memory button, I could hear the relay module clicking in the passenger foot well.
My other symptom I forget to mention was my right mirror would go all the way right when using the memory buttons. BUT I could individually move it with the mirror button no problem.
Sorry for all the excruciating details but I thought you may have the same root problem and thus a solution.
If you find bad wiring, I would repair it see if that corrects the issue. If not, it looks like more troubleshooting or living with it!
Best of luck!
Mo
