1 - 15 of 15 Posts
After seeing this image I really really want this steering wheel now. I found a few on ebay but the prices are high. I need a w140 wheel. Is the bolt the same?
1990 SEC
I agree, that wheel is very good looking. I may be wrong, but I think it is a W124 steering wheel and should fit out W126s.
I would also like to know where the extra door wood can be purchased. I found a UK website, MercedesPerformance.com, that sells a wood panel for the center part, replacing the leather covered panel, but I think the wood in the picture looks a lot better.
Moderator
Mercedes
AxelWulff - 4/20/2005 3:20 PM
Many AMG's had those wood trim around the doors... could be an AMG mod?
1985 300sd
Yes, the wheels utilize the same bolts. Virtually all Benzes up to the year 1999 or 2000, w220 excluded, have wheels that will work in our cars.
Wicked so sounds like an easy job? I dont have the telescopic steering or airbag system! All I need to do is find the steering wheel for a DECENT price. Im going to this one place tmrw but I have a feeling I wont find it.
If anyone knows?
1985 300sd
Super easy. Just pull the part of the wheel where you hit the horn towards you. It will come right off. The bolt that holds the wheel on is 14mm if I recall correctly, but I honestly can't remember, as it has been quite a while.
this is the exact wheel that i tried on the car afew months ago...please do a search to see the thread.
it looked good...felt good...but unfortunately cuts the vision of the instruments from the top, and both sides....if our wheels had vertical adjustment, there would be no problem, but no matter what, i couldn't fix the problem (and that included sinking the seat as low as it would go).
but i do agree....it looks great....i'm tempted to try it again. how much are you being quoted...here the wheel was offered to me for $400.
by the way, its not a simple 'plug and play' scene. you need a mechanic who knows what he's doing, as there is some retrofitting required to the back of the new wheel before it will work properly....not a big deal, but not a diy job..imo.
Mercedes Benz 500SEC
I have the exact same wheel except tt i have a special limited edition mercedes benz badge in the centre.
1982 300D Turbo
Check with tiger_biru because he/she will be putting the factory wheel back on his/her 123. I think its the same wheel.[;)]
Discussion Starter #11
hmmm it doesnt look like tiger's wheel is obstructing the view of the gauges? Was it just maybe the wheel you had?
Benzonline - 4/21/2005 9:31 AM
no...it looks fine in the photos...the wheel was the same (except in zebrano wood). but in reality i think its a little different.
would the current owners of such wheels care to comment on the instrument visibility factor???
12-Camel TT S600
dont worry abt the instrument panel vide being blocked.. your experice will teach u how to figure out speeds and rpm's by need position at its pivot point.. the rest gauges hidden more aggresively dont need a frequent view.. every now and then on highway.. u can bend ur head and give it a peek..
Discussion Starter #14
Yeah im sure its not a big of an issue. [:)]
Discussion Starter #15
ok...I managed to find a place in town with these steering wheels but they had no covers which was one problem. Another problem was I still dont think it will work and the guy said it wouldnt eitheir because of the slider rings and connections. From reading this thread my impression was just to plug n play but its not.
How was it done exactly?
1 - 15 of 15 Posts
