1 - 20 of 21 Posts
1973 450 SL
Just out of curiosity, how many of you that have removed your steering wheel used loctite when you put it back on, or did you just simply torque it up and leave it that way?
I haven't removed mine yet but will be this winter to remove the instrument cluster to clean and polish the clear plastic and at the same time replace all of the bulbs. The wheel on mine has never been removed and man did they ever apply a lot of green loctite to it in the initial install.
1997 SL500- 40th Anniversary
Locktite on mine was red...
I did not use thread locker upon install.
R/C107 Moderator
The green was used on both my '72 and '73. I did not put any back on the '73. The '72 (needless to say) was never reinstalled.
Much easier to remove the nut than the 10mm hex bolt. No heat needed.
2010 Mercury Milan Hybrid, 1993 BMW 325i convertible
Mine wasn't loctited when I got it, and I've never bothered to. Amazingly, the steering wheel has not yet fallen off during a tight maneuver.
If the car ever gets to the point where there's absolutely no chance of anything ever breaking on it again, I'll consider putting some loctite on it. Since I'm pretty sure I'll have to remove the steering wheel one or two more times, I'll leave it as it is.
Loctite Red is is the high strength stuff for parts that will seldom or never be dismantled. Blue is for parts that may have to come apart sooner. Never heard of green, but maybe that was a pre-Loctite product?
But, Loctite is a big rip off! Here in Canada, it costs about $20 for a small (10ml bottle) and then they say to use a primer - $40 for a tiny spray can at Fastenal!
In order to keep this legible, lets consider a table. Copy the table below, paste into your reply, then add your data...
Owner--------------car-------color threadlocker------replaced with color
Ears------------1988 560SL----Red-------------------No
Scottin SoCal---__________----None------------------No
Rowdie---------__________----Green-----------------No
R/C107 Moderator
Nice idea.
Rowdie---------1973 450SL----Green-----------------No
1973 450 SL
Discussion Starter · #8 ·
Nice idea.
lfedje-----------1973 450SL---Green-----------------Probably won't
Scottin SoCal---1978 450SL----None------------------No
MBGraham-----1972 350SL---?????------------------?????
82 380SL 96 SL500 03 SL500
Abiby----------1984 380SL---Red--------------------Hell No!
I actually thought a few days ago that the bolt had come loose as there was some play in the wheel itself. It turned out to be the philips screws holding the bracket in place. I'd probably never tightened when I had it all apart last winter. :eek:
Nice idea.
I'm guessing Nobby's is green.
1975 Mercedes 450sl & 1979 Mercedes 450sl & 1978 450SLC
Judy-----------1975 450SL---Green-------------------No
83 280 SL- 5 speed-The PIG
Nobby ________1983 280SL__________None________Hell No
In fact I installed a zipper so I can remove it even faster.
1987 Mercedes-Benz 560 SL
GlueckAuf-------1987 560SL----Red------------------(Very Little) Red
Roncallo--------1986 560SL----????-----------------Blue
Roncallo--------1988 560SL----????-----------------Blue
No fair cheating! :)
If I recall correctly, when you removed your original wheel, the pic you have of the screw lying on the steering wheel has faint evidence of red threadlocker... or is that rust?
1986 560 SL
Dugald ............1986 560 .......Red .................... no
1986 300 SL Euro spec - Signal Red/Black Eng/Trans: Inline 6 (M103.982) / 722.322 Auto
RenatoMB..........1986 300 SL....Green (I think, its on top, havent removed it yet see photo) ...... probably not
BTW, (dont mean to hijack the thread) do I have to take the steering wheel off to get the instrument cluster out ???? Thanks folks and sorry to interrupt.
R/C107 Moderator
Where would we be without straying and Hijacking. MBCA, that's where.
Unfortunately, yes. You do have to remove it.
Removing your steering wheel builds character. :thumbsup:
1 - 20 of 21 Posts
