2007 E350
Just purchased a 2007 E350. Recently I noticed the steering wheel stopped moving up after the key was removed. Did I accidently disable this feature?
Super Moderator
If you do not hear the motor trying to raise the column then it most likely got disabled.
Are you using the same key? The feature can be set to be key dependent.
2005 E320 CDI (W211)
If you moved the seat manually, or moved the steering column manually, you memory position will no longer be "active". To reactivate, hold down the appropriate memory button (1, 2 or 3). This should re-enable the auto steering column option....so long as it's enabled in the system settings. You can check this on the multi-function display. Settings..., etc.
2007 E350
Somehow I accidently disabled it. I fixed it at the multifuction display settings. Thanks for the feedback.
