2002 Mercedes Benz G500, 1981 Mercedes Benz 300D
Hello,
I have a torn steering shaft boot on my 2002 G500, so I got a new one from the wonderful Vlad and this has to be an easy job but before I try and tackle it I just wanted to make sure. The stealership said it would take 3 hours and that I just cant believe. If anyone has ever done this before or if you can shoot me any advise I would more than appreciate it. THANKS
04 Adventurewagen
The steering boot needs to be installed from the inside. It is captured between the steering column and the firewall.
So it is a fairly complex job, removing/disconnecting the airbag, removing the steering wheel, removing all the electronic switch interfaces and so on.
It is doable and I have done it to repair the steering shaft.
one big notice: disconnect the battery first, do not turn on the ignition switch before the airbag is completely reconnected.
