BMW, but Benz-curious
Looking at buying a 99 E300TD sedan for its engine, presumably with a single-vane power steering pump. I'll be running hydraulic brake assist, and that leaves me with three options. The default is importing 002466190. Two others I'm less sure about.
1. Can I bolt an M112 pump to an OM606? The mounting bracket looks at least close. Specific donor in mind is a 10/01 E320 4Matic wagon. The pulley size may be different, but I'll need a non-stock belt length anyway as the AC compressor and alternator will likely be relocated.
2. Can I have a custom hose made to split a single pump's output to brakes and steering? I know how to drive and won't be sawing the wheel while standing on the brakes anyway, but to be sure, is there another reason OE setups use a dual-vane?
Discussion Starter #2
Whoops, should be 0024661901. EPC lists that as a tandem-vane pump for W210 E300 turbodiesel wagons with SLS and/or ASD.
1998 E320s sedan and wagon
You might be able to use the tandem pump from a W124 300TD or TE. The second pump is for self leveling suspension. The OM603 has a similar block to the OM606. The M104 pump might fit.
Sixto
98 E320 wagon 197K miles
Thanks, but the whole thing is moot. First, looking into hydroboost, it turns out that a practical solution is to plumb the brake and steering assist servos in series (brakes first), so no need for a parallel circuit like a tandem-vane. Second, I decided against hydroboost altogether, since there's a (sort-of) plug and play solution to relocate the vacuum booster; I'll just use vacuum brakes instead of hardware that's about $1200 and a sourcing headache to replace if it ever croaks.
