I have read many threads about this. Does this adjusting screw (#47 in manual) adjust the friction torque of the power steering or does it remove any play it has inside the box to get the 1" free travel of the steering wheel on the circumference?
Please attach picture from manual.I have read many threads about this. Does this adjusting screw (#47 in manual) adjust the friction torque of the power steering or does it remove any play it has inside the box to get the 1" free travel of the steering wheel on the circumference?
I believe this might answer your question. See post #10Please attach picture from manual.
Sounds right. Thanks
That screw #47 needs to be adjusted after the end cap nut, See post #3 which refers to post #10 in another thread. Both will cause excessive play at the wheel. The end cap nut should have a set drag torque to ensure there is no play from the ball nut and input shaft assembly. Screw number 47 is to be adjusted with the steering box on center, since the pitman gear has a high spot on it in the center position. Essentially #47 is the screw that the 1" of play comes from because the end cap nut is supposed to have zero contribution to the play if adjusted correctly.
