1986 300SE
I called my local dealership to try to purchase the proper insulation pad for under the hood, mine is shot. They want $105. Correct me if im wrong, but isn't this considerably high?
1988 560SEC, 1987 420SEL, 1986 500SE
Yessir, mine was 30-some dollars (InterAuto, SD).
1990 Mercedes 560SEL
You will get better quality one for $44.20 from www.performanceproducts.com. You can also contact Jonathan and he will probably give a very good one for a cheap rate. (I found that this always the case with stealership, I even compared their parts to the other one. Example: Windshield wipers and brake paste. The only thing is stealership has Mercedes name on it. Others may not have it. But quality is the same or better)
Ramesh.
500SE AMG, E350 4matic, GL 450
Bought mine from autohauz AZ. With the purchase of the adhesive, it was under $50 to do (if I remember correctly)
Black 560 SEC AMG, White 560 SEC Carat (RIP 09) , 300E
i got quoted one for $126 Aust dollars including delivery...prob $70 to $80 US
