1988 420SE, 2002 C180 Kompressor, 200 ML320
Poor starting & Burning oil
Nawaid
It sounds to me like the Thermo time switch (engine temperature sensor) is not working. Its situated at the front of the head on the right as you look at the engine. It is cheap to buy and just screws in.
Don't be confused with the temperature gauge inside the car, that works off a different sensor.
The oil burning is probably worn valve stem oil seals. The head does not have to come off to replace the seals, as MB have a specail tool that allows them to be done in situ and it only takes 2 hours at most. Take it to an MB specailist who has the tool.
If the car has very high miles, it could be more serious i.e. valve guides or even piston rings.
Nawaid
