1 - 20 of 23 Posts
1999 Mercedes-Benz c280 sport
So I have poured over the forum threads looking for related issues. Car starts and runs for about 15 minutes then it shuts down and won't restart for bout 30 minutes to an hour. My first instinct is Ckps but the code stored is p01570. I know for a fact that Ckps won't show in error codes have had 3 cars do the same dang thing. The car is a 99 c280 sport 2.8v6. I checked all fuses everything seems to work inside lights seats and so forth the scan with my Apollo d8 only brings the one code...
w163 02 ML500 W210 97 E50Amg w202 99 C230K w124 - need more space, time to build again
Welcome SyntheticD,
Have you seen this?
Also, were you scanning only at the obd2 port?
What about at the 38pin?
Not familiar with your scanner though.
My scanner is made by Snap-on don't know if I have the 38 pin connector I will check. And I'll read the article thank you..
W202 230K Sport manual & a few non Merc's
P1570 Possible Causes
  • Incorrect/damaged key
  • Key incorrectly coded
  • Faulty Engine Control Module (ECM)
  • Faulty immobilizer
Here's my 2 cents worth...
It could be any of the above and also a wiring issue or a fuse as mentioned in the above link , doubt it's either of the latter two. First thing I would do, as it's easy and costs nothing, disconnect the alarm siren (driver's side front wheel arch next to the bumper). You can also try disconnecting the battery for 30 mins and reconnect.
After that I'd get a new key...then I reckon you'll need the assistance of a Merc specialist.
Honestly I just wanna keep this car running but I'm not spending ungodly amounts of money for 150 dollar car... Plan is to use it for the gambler 500. So if it comes down to getting a new key I'll sell it as is.
Well, two of the suggestions I made will cost you nothing!
Ok so I just noticed as I went to check the voltage at the battery while running the positive terminal is getting hot like untouchable hot. Not the terminal itself but the 3 larger gauge wires connected to it
That's not looking very healthy to me.... poor connections case heat at the positive terminal that's either janky or ready to burn down the car....i have a spare terminal is it ok to bind all those wires together and put them in a new terminal...?
2621691
Discussion Starter #11
As a update the code hasn't returned and the car died once for a second but came back on. The code still didn't return... I'll leave for the night and try again tomorrow
1995 C280 (165K mi)
What is the general condition of the car? Is this a total POS?
If so just sell it and don't bother if you already feel spending $150 is too much.
Discussion Starter #13
its pretty rough but thats the idea cheap car run the gambler 500 Idaho/Oregon if it survives awesome run it till it dosent lol. in all honestly the motor and tranny are super smooth no misses the tranny shifts good. it has pep in its step. my Mercedes experience is very limited due to the area i live in im a full time mechanic but i dont see many euro cars.. except i own a couple lol
Discussion Starter #14
As of now the car still shuts down and starts once it cool down.. during the no start there's no fuel pressure. If that's any clue still no codes storred or present.
Discussion Starter #16
More updates seems I can hurry the process of waiting for the restart along fast but inserting the cycle to on for a minute turn off do it again after 3 to 4 times I can hear the fuel pump kick on and then it will run for as long as I let it..... Such a strange thing...
Discussion Starter #18
I just got one from Napa we will see if that work or not this afternoon. I didn't feel like dragging it to work with me lol even know most of my good tools are here its a E8 right for the bolt?
Discussion Starter #19
So....... I'm pretty sure checked fuses really well. But the 23 fuse under the hood was blown replaced it along with the cps and now it's been running for about 45 minutes
Discussion Starter #20
Problem seems fixed not sure if it's fuse 23 or the CKPS but definatly solved the issue
1 - 20 of 23 Posts
