This might help
Put in your model year to assist other members -- This inf. is for a 4 cyl W202
2 parts - diagnosis and then removal
Oberoi
1994 Silver C220
Nice post oberoi. You always come through with your posts. I believe it's the same for the 98 c230 kompressor sunnfyfx.
I read the image attachments, but what I noticed is that, when the key is turned, it makes the click sound, the lights dont dim at all and nothing else happens. No starter movement, nothin.
We've been jumping the battery to get it started for a few days now. Should the batter be replaced all together? And if so, would a $90 Autocraft or Duralast suffice?
So it starts when you jump it? - replace battery?
Check how old first - over 3 yrs is always suspect tho' Benz batteries seem to last longer
You'll probably need Eurostyle which is not as tall as old style batteries - Check the rating in your handbook for replacement size. The clips in the trunk will accomodate almost any size battery
There is nothing mysterious about batteries - any good quality unit of the right rating will do. check the height of your old unit and use that as a guide to ensure that the terminals don't foul anything
Oberoi
