When I turn the key, the flywheel spins and I hear a click but the engine will not turn over. I suspect that the starter motor or starter solenoid may need to be changed. Where is the starter motor located on the mercedes 190E?
1986 190E 2.3-16, 1992 190E 2.3, 2015 GL350 BTC, and 2020 GLS450
Whether on the 2.3 or 2.6, the starter is at the driver's side rear of the motor. It is a metal cylinder (the size of a small coffee can). You can see it if you crawl down behind the left front tire and look past the inner tire well and up. Use only an original equipment replacement.
'87--190E 2.3-16v(being rebuilt), '99--C230 Kompressor
it's held on my by 2 ea 17mm bolts that are a bitch to get at due to location. if memory serves me correct you have to access the bolts from the bottom of the car
Oh yes. The bolts have to be removed only from the bottom of the car.
There is a detailed replacement process which involves removing the driver's side engine mounting strut prior to removing the starter. However, on my 2.3, I was able to simply maneuver the starter away and down without removing the mount/strut.
1984 190 E
i need to remove my starter and replace it and i am looking for some kind of instructions so I can take it out. then take it to a shop to fix. any suggestions will be appreciated.
