I was wondering where the starter would be located at on a 2003 Mercedes-Benz SL500? ive been looking and looking and am having trouble finding out....any help would be gratefully accepted and appreciated. Please and Thank You.
2004 CLK 240 Coupe
You will only see the starter from under the car if the engine compartment under-panelling is removed.
To remove the starter, first disconnect both the starter & electrical system batteries.
Next, remove the electrical connections at the starter and the cable clamp, undo the 2 securing bolts, and remove the starter downwards from below the car.
2003 SL500, 2012 E350 4Matic P2
Attached are WIS (Workshop Information System) instructions for reference.
What symptoms are you experiencing?
Also, don't forget to use the search function which has a pull down box to enter your search words such as Starter motor. You will be surprised how much members have shared concerning the more common DIYer projects that MB owners encounter. Don't forget too that the M113 motor which is in the early R230's, (02 UK-06 US), is shared with other platforms in the MB model lineup so searching in those forums can also add to your knowledge on a specific related project................
Good Luck,
Bob
