1 - 10 of 10 Posts
my starter clicks but doesn't turn and the lights dim when i try to start it. If I Hit it with a hammer it will turn but disengages before I can get it to start.
I've replaced many starters but not a MB Diesel. Any tricks or tips before I climb under it to pull it out?
thanks!
1984 300D Turbo
yeah they are a bitch to get out you need a breaker bar. better take a new starter to your favorite indy with a lift and let them do it unless you have a lift and are hurcules.
so i hear the top bolt (hex ) is the one that's difficult.
1959 220S cabriolet, 1983 240D original owner, 1999 E300 turbo diesel, 1988 560SL, 2003 SLK320
What model? 240D can come out from below in about 10 minutes. 300D is quite a bit tougher to do.
Len
1984 300CD, 2015 Sprinter 3500, Coach House Platinum II
I've done this 3, three, did I say THREE times[xx(] I had the same symptoms the first and second time. I use a #10 allen socket with a #10 box end rachet wrench on it to turn it. This is for the upper allen. For the bottom I use a standard "L" shaped allen with a box end on it as kind of a breaker bar to loosen it up. The last time I did it I got an estimate from the local indy MB mechanic. He wanted $450, 2 hrs labor @$75 and $300 for the starter. I bought one on line about $100, rebuilt Bosch, free delivery and I had a coupon. I timed my self and it took me 50 minutes, but then I've done it 3 times, three. The first time because the one that was in it when I got the car was a non turbo and was dying. The second because the first rebuilt bosch was a bad one[xx(] and the third three years later, all on the same car.[8D]
The first time was the worst[xx(] a real b&%#ch[:D] but I did save a lot of $$$$
1984 300D Turbo
MBZ300CD - 2/1/2005 10:58 PM
i'm assuming he's got a 300D turbo. ??
$300 for a starter?? - you need to find a new indy that one is a rip-off artiste...
1984 300D Turbo
stemple - 2/2/2005 2:17 PM
sokoloff - 2/1/2005 9:57 PM
Len
its a 240d
I just picked up the starter
what kind of starter? some folks have said that the heavy duty bosch makes 240's start easier.
1 - 10 of 10 Posts
