1 - 8 of 8 Posts
1979 450SL UK spec
One day I hope to get it to look close to a factory fresh look but I am along way from that now, most of the job will need to wait till I take the car off the road this winter, but made a start on the intake housing.
Not an easy shape to clean the ingrained grime off of.
I used cut up grey scotch-bright swatches and metal polish by hand as there is no easy way to get a power tool in there.
The results were better than I expected.
I will need to remove all the fuel lines to get to the rear section and will re-plate and yellow passivate them at the same time as well as repainting the FD.
Over the winter I hope to get all the fuel lines and brackets etc re-plated too so should look much better next spring.
Of course Mrs RD says I'm an idiot as its all covered up by the air filter, too true!
Very nice Jim - my FD is in a similar condition and I'm planning the same work next winter season plus the steering linkage. This is @Martin_fromGermany 's baby, and I'd like to get to that condition by next spring-ish ;-)
2642589
P.S. My wife has a very similar (worse) perspective on me and my affection towards Eleanor, you're not alone :D
1979 450SL UK spec
Very impressive, It would be great to find a pic of a 450 K-jet in that kind of a condition to see what needs to be done.
For instance I am not sure if our steering pump lid should be painted or passivated.
Here is my plating system, however I am not happy with the new "eco" friendly passivation colour and have ordered some sodium dichromate to get closer to the original condition.
One of the first parts I tried, to pale and too pink in some light.
I'll look for a Kjet, I'm sure we can find a good pic somewhere. Re the lid, mine is defo passivated though yours, being a later chassis, might be painted.
At any rate Jim, that's a beautiful set up you got there - kudos! That piece doesn't look bad at all for a test drive. 👍👌 Let us know when we can start shipping stuff to your door step 😉😁Here's another pic from my favourites, I believe this finish is close to the factory look.
2642952
1 - 8 of 8 Posts
