1999 C-280. & 2000 SL500
Can someone tell me why I get the following message every time I try to open this CD Manual " Wrong Disc Inserted " It is not as if I have not run it before I have. Just lateley it will not work. Help
SL500, CL55, E350, E320
could you open it manually or it doesn't work either ways? if you could open it manually (go to the directory and click on the exe file itself), then might be your 'run' file points to different location. if you cannot open the disc at all, your disk might have gone bad or the cd reader went bad, try another computer to narrow down the problem.
· Outstanding Contributor
2005 SL600, (2) 2003 SL500
Mine will do the same thing. My work-around is to run it by launching "classic\home.htm" from Windows Explorer.
