1 - 9 of 9 Posts
2001 Mercedes Benz ML430 w163,2008 Mercedes Benz CLS550, RIP Mercedes Benz 1996 e320 w210
Got a stalling issue car just cant hold the steady rpms during idling and stalls
So parts are on the way:
Part #: 180-0421
1996 Mercedes Benz E320 Base 6 Cyl 3.2L Beck Arnley Crankshaft Position Sensor Crankshaft Position Sensor E320
Beck Arnley
Qty: 1.00
Price: $ 59.34
Part #: REPM960904
1996 Mercedes Benz E320 Base 6 Cyl 3.2L Replacement Oxygen Sensor Oxygen Sensor E320
Replacement
Qty: 1.00
Price: $ 72.83
Part #: BEH208287312
1996 Mercedes Benz E320 Base 6 Cyl 3.2L Behr Thermostat Thermostat E320
Behr
Qty: 1.00
Price: $ 13.44
Now can some direct me to a thread on how to replace CPS sensor on M104 engine?
Discussion Starter #2
PS i have just replaced my Auxillarry Fans and decided to check for the location of my CPS sensor and I could not see it??
I know most of u guys have V6 and all DIY are for M112 engines but is there one for M104?
I understand that it is in the same approximately location as the M112 but some tips on those who know for sure where it resides would be greatly appreciate!!:D
Return the Beck Arnley CPS before you use it, if you can, and get genuine Bosch.. non-Bosch have short lifes really..
My other concern - bad CPS causes either hard hot-starting, or can cause warm engine "cut-off" .. meaning the engine cuts out like a switch has been flipped..
If you have idle problem, or feels like engine is "choking" then there are other issues/things to check.
Keep the beat !
Outstanding Contributor Always Remembered RIP
216 with everything. 2002 SL500 with everything. 2009 SL500 with everything.
The CPS usually fail fails when hot, due to materials used that have different expansion rates in the potted construction.
Look at the rev counter when cranking, if it is not reading anything then probably the CPS
Yea it's like a cut off. It just shuts down
Sent from my Autoguide iPhone app
Yes the car gets warm or hot and it cuts out, but restarts when cooler then 99% the CPS
It restarts but dies cuz can't hold Rpms
Time for a CPS anyway - but understand non-Bosch can lead to short CPS life..
Like $65 aftermarket for Bosch here in US.
That should stop the "cutoff" issue - if the idle issue sticks with you then we will need to go off into other areas if it is separate 2nd/3rd issues - depending on mileage if RPM/idle stays a issue then 2nd base is MAF check, then 3rd base is throttle body..
First things 1st
Yea true. My car has a lot of mileage 267000 kilometers. I have changed the MAF before about a year ago with a Bosch one. So the only thing I am worried is that it could be the trotter body in which case I am f****** since there is no simple sensor on it that I can replace
1 - 9 of 9 Posts
