Have read a number of threads, usually with suggestions but not any posted results.
1999 S420 147k (yes I drive it, ALOT) usually average 3000-4000 per month.
On Monday I was headed to airport. Very happy as I just had upper and lower ball joints done, got rid of the horrible second set of Lemfoerder coil springs and a spiffy new set of 255/45 18 Michelin Pilot Sports installed. Was enjoying the smooth responsive 1 hour trek to airport.
When I arrived at airport, got myself into garage and was headed up to the upper levels to park for the couple days I was to be away. Upon entering the first incline the car stalled while driving. Couldn't get it started. So of course a dozen culprits flash through my mind. Would turn over, but a second or two it would die again.
I went looking for the parking office to garner some assistance. Found no one.
Returned ten minutes later, tried again and no start. Same deal.
Sitting there contemplating the business trip to Dallas, I tried again and by manipulating the pedal I could get it to start and run but if I let off it would die. At this point, I had no check engine light come up but the whole dash lit up when it stalled.
I was able to 'power brake' it into a nearby parking spot, and I decided to get in my flight and deal with it when I got back.
Last night, I decided I had to at least get it out of the airport garage because no tow truck could load within the garage. Once I got going, I kept going knowing my route had good phone service if I needed to call AAA.
Keeping the RPMs up, I made it home. It died in driveway. Did notice that the MPG gauge needle was swaying back and forth between 15 and 35 the whole way home, but otherwise no issues with power once accelerating.
This morning, I set out to do a precursory inspection of the items I felt could cause this. First checked the basics - K&N filters clean (recharged a month ago), no obvious vacuum leaks, fuel pump humming away with key on and still no check engine light. Ok, I thought, now to get into it.
I removed MAF and gave that a cleaning. It looked clean, but I did it anyway. Looked at throttle body and it too was clean. Looked inside plenum and it looked good. MAF gasket was whole and showed no cracks. Couple new clamps and I reassembled. Checking torx bolts on throttle body for proper seating and tried to start. Same issue.
Thinking there MUST be a massive vacuum leak, I rechecked all the lines. Broke the plastic of the front most line and replaced it. Then thinking that maybe I had a brake booster failing, I disconnected it, plugged holes and tried starting. No difference.
At this point I got a check engine light.
Now I am awaiting a friend of my mechanic to stop in tomorrow night to read code (mechanic just had stints put in and is out of commission for a bit) but I am wondering if there is something else for me to check?
Plugs have 10k and two I pulled looked good. Suppose I could pull all of them and make sure. I religiously use Techron every 5k. Fuel tank over half full.
As of a few moments ago when I needed to move the car to get my Zetec powered Vanagon out of driveway to use tomorrow the MPG needle is pegged all way to left.
When I get car going, and manipulate the pedal, I notice no skipping or misfires, but I could be wrong (frequently am according to wife)
What am I missing here?
Pre owned CLS550 at dealership this morning is looking better every moment.
