Does anyone know how much the tread life of the tires are affected (if any) by using lesser width tires in the front and wider width tires in the rear?<br>
<br>
on a W124<br>
<br>
Thanks...
Discussion Starter #2
About the only thing that will affect your tire life is YOU. How fast you accellerate, stop, and corner will determine the life of your tires. If you keep them properly inflated (check the sticker on your drivers door), and keep the car aligned, your tires should last quite a while.<br> <br> Tim
